Te koop,
Zeer nette draggun plasmacutter, all in one dus compressor ingebouwd!.
Na uitgebreide servicebeurt niet meer gebruikt, gaat weg wegens overcompleet.
Thermal Dynamics Drag-Gun
FEATURES:
•Portable plasma cutting system with built-in air compressor
•Maximum convenience and portability
•Maximum arc visibility and excellent operator control
•Condenser minimizes moisture in the air supply
•Includes humidity removal kit
SPECIFICATIONS:
•Cut capacity:1/8 (3.2mm) genuine cut
•Output current: 12 amps fixed
•Input power:
•230v 10pct), Single Phase, 60Hz., 22 Amps
•Duty cycle: 30pct @ 12A
•Work cable: 15ft
•Input power cable: 6ft
•Gas type: air from built-in air compressor
•Pilot: electrode tip
•Control: hand torch switch
•Torch: PCH-10
•Torch configuration: Hand 70 or 180 20 Leads
•Approvals: CSA, IEC974, CE
•Dimensions: 10'' H x 9'' W x 16'' D
Referentiemateriaal : http://www.ebay.com/itm/THERMAL-DYNAMIC ... 4ad724b34c
Manual: http://victortechnologies.com/IM_Upload ... al_(0-2682)_April2006.pdf
Let op!, heeft minimaal 230v 16a groep met trage zekering of C type automaat nodig.
Prijs 399€
