door M. van der Meulen » 16 aug 2006, 22:28
@Mike,
Looking at the first picture it seems to me that the speedometercable has just been cut off, and that de plastic tube it is supposed to fit in has been damaged at the outer ring. This will make it harder to secure it onto the differential with the metal pin. The tube may start spinning around a bit which may cause even more damage to it.
Without changing the speedometer connectionclip at the other end you'll need a cable of exactly the same type. The one on Marktplaats I brought to your attention won't do, it fits on mine however, same length, same connectionclip.
When inserting the (new) black connectiontube make sure that the securing pin on top of the differential is removed completely, and that the little hole in the tube is in the correct position. That's the only way to secure the lower clip into the tube. Good luck, M.
104 SL 06-'78
104 S 08-'79
307 SW Société 2.0 HDi 11-'04
Ami Super Break 03-'73
