Samba cabrio headlight wanted
Berichtdoor mmarks » 25 aug 2006, 09:13
Does anyone know where I can get a headlight for my Samba Cabrio (I assume any Samba would be the same), the reflector in mine is very rusty.
I went to http://www.depopulier.com and they had a Samba, but the reflector was very rusty on that one too.
I tried a Peugeot dealer but they had no access to Talbot parts listings (or anything older than about 10 years).
Many thanks, I hope you can help.
mmarks
Geregistreerd: 18 jul 2006, 13:29
Berichtdoor Brownie » 25 aug 2006, 10:29
Is that the same light as on the 104?
I think the most change, and the least expensive is to check car demolishers for used parts. Where are you from? Maybe somebody can give you tips in your neighbourhood.
403 Break Diesel 1960
104 GL6 Benetton 1978
504 D Pick up 1981
604 DTurbo 1979
505 V6 BVA 3X
505 GTI Familiale RHD 1987
505 GR Familiale 1990
505 SW8 BVA 1991
205 Accent 1991
306 Cabriolet BVA 2.0 2X
206 XS 1.6 SW BVA 2005
Brownie
Woonplaats: Nederweert
Berichtdoor mmarks » 25 aug 2006, 11:08
Not sure if the headlights are the same!
I am in Uithoorn, Noord-Holland
mmarks
Berichtdoor Brownie » 25 aug 2006, 11:18
You can contact the Jonkhart family in Hilversum. Maybe they can tell you if there is a difference between 104 and Samba. With a bit of luck they have some lights in stock.
504 D Pick up 1981
604 DTurbo 1979
505 V6 BVA 3X
505 SW8 BVA 1991
205 Accent 1991
Brownie
Berichtdoor mmarks » 25 aug 2006, 12:50
OK thanks for that advice, do you have any contact details for them or a web address. And lastly who are they and what do they do?
mmarks
Berichtdoor Brownie » 25 aug 2006, 13:20
I myself don't know them. What I heard is that father and son Jonkhart run a Peugeot garage. They specialize in the older models and have a lot of knowledge and spare parts for those cars. They are mentioned often on this forum. Try to search (zoeken) 'Jonkhart' on the forum and you should find an adress somewhere.
Edit: found it already:
Jonkhart
Geuzenweg 249
Hilversum
telefoon 035-6857111
I'm not sure if they talk english very well.
504 D Pick up 1981
604 DTurbo 1979
505 V6 BVA 3X
505 SW8 BVA 1991
205 Accent 1991
Brownie
Headlights
Berichtdoor Rudie_Krämer » 25 aug 2006, 15:52
The are very rare in Holland, they are not the same as the 104 headlights.
I have them for you, I think I even have new ones, but also used ones
Which side do you need?
Greetings Rudie
Maybe you can sent me a personal message with your phone number
Greetings Rudie
Rudie_Krämer
Woonplaats: Delft
Berichtdoor mmarks » 25 aug 2006, 17:28
Thanks for that, I have sent you a PM (I think I did it right!)
mmarks
Berichtdoor Rudie_Krämer » 25 aug 2006, 20:29
No it didnt work
Private message ( push button PB )
Or My Email: kramaldo@gmail.com
Try again please
Rudie_Krämer
Woonplaats: Delft
Keer terug naar 104
